Thread: OLE (eg Excel) Objects within drawing file not Plotting correctly
    13,656
    2001-12
    St. Louis
    5,408
    Default Re: OLE (eg Excel) Objects within drawing file not Plotting correctly
    Quote Originally Posted by Mike.Perry View Post
    Experiencing issues / problems with OLE (eg Excel) Objects not Plotting correctly from within a drawing file, the below information might just help resolve such issues / problems....
    Links:
    Autodesk Knowledge Base:
    ID: TS21730 - Limitations of using OLE objects
    ID: TS71114 - Some OLE objects do not plot
    ID: TS47508 - Determine driver to use for optimal plotting of OLE objects and raster images
    ID: TS33804 - Improve plot quality of OLE objects
    ID: TS73483 - OLE objects with Plot Quality set to Line Art do not plot
    ID: TS21323 - Control plot quality of OLE objects
    ID: TS1059077 - Rotating OLE objects
    The URLs to these knowledgebase articles have changed since Autodesk redid their website. Simply copy the ID # provided and search the knowledgebase to locate the new URL for any of these referenced articles.
    Melanie Stone
    @MistresDorkness
    Technical Editor
  1. Import points into drawing file from Excel
    By msanders.85217 in forum AutoCAD Civil 3D - General
    Last Post: 2013-07-16, 11:41 AM
  2. Linked Excel file plotting upside down
    By emlyn_altman in forum AutoCAD Plotting
    Last Post: 2007-05-15, 10:32 PM
  3. Replies: 2
    Last Post: 2006-05-02, 04:41 PM
  4. Working with OLE (eg Excel) Objects within a drawing file
    By Mike.Perry in forum AutoCAD FAQ (Read only)
    Last Post: 2005-03-26, 07:45 PM
  5. Unable to select OLE (eg Excel) Objects within drawing file
    Last Post: 2005-03-26, 07:05 PM
