Thread: When Plotting from Sheet Set Manager, font prints incorrectly
    2004-02
    8
    Question When Plotting from Sheet Set Manager, font prints incorrectly
    If I open my drawing from SSM and just plot normally, the font from the (xrefed) titleblock prints fine. However, if I plot from the SSM palette, the font prints like romans.shx. What would cause this?
    2009-11
    5,719
    Default Re: When Plotting from Sheet Set Manager, font prints incorrectly
    Romans.shx is likely just set as your 'alternate font' in options.
    Double check the Page Setup Override you're using to issue the plot(s) - it's probably not configured the same as the named Page Setup for your drawings.
    If/when you get tired of dealing with Publish, Plot, PDFExport, etc., consider the Autopublish mechanism, which lets you produce PDF on SAVE (as example), and in less time than it takes for any of the other 'plot' methods.
    Cheers
    Computer Specs:
    Earth
    9,805
    If you have background publishing enabled, disable it and try again.
    Any difference?
    R.K. McSwain | CAD Panacea |
  1. Plotting using Sheet Set Manager
    By woodychang in forum AutoCAD Plotting
    Last Post: 2010-06-08, 02:00 AM
  2. Sheet Set Manager / Plotting to PDF
    By bcole.200021 in forum AutoCAD Sheet Set Manager
    Last Post: 2009-03-04, 05:33 PM
  3. Sheet Set Manager Plotting
    By c.mcmahon in forum Project Navigator
    Last Post: 2009-02-02, 05:27 PM
  4. Multi sheet plotting in Sheet set manager
    By tim.ashton in forum AutoCAD Plotting
    Last Post: 2007-01-27, 02:00 PM
  5. Problems plotting from sheet set manager
    By jwilliams.67235 in forum AutoCAD Sheet Set Manager
    Last Post: 2005-07-05, 09:12 PM
Tags for this Thread
