Thread: Merge Text Styles
    2016-07
    Default Merge Text Styles
    I am using Civil 3D and have drawings with various text styles that I want to merge together.
    So I would need to type in the unwanted style(s) then the new style name. To be simple I have renamed the unwanted styles to number 1,2,3,4 etc. and I want them to be merged to the Standard style.
    I have found and tried a hand full of various routines that will not work.
    Because this is a Civil 3d Drawing I need to truly merge the text styles (not just pick objects and change their style.)
    Is this even possible?
    Thank you,
    John
    Civil 3D 2016
    AUGI President Kimberly Fuhrman's Avatar
    2015-10
    York, PA
    63
    Default Re: Merge Text Styles
    I've used this solution with success in Civil 3D...
    http://forums.augi.com/showthread.ph...ge-Text-Styles
    It requires a very unusual mind to undertake the analysis of the obvious.
    --Alfred North Whitehead
    Kimberly Fuhrman, LEED AP BD+C, Assoc. AIA
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,665
    Incredible dialog box routine by Tim Willey that lets you select as many styles found in use to merge in one column and select the style to merge to in another column. Options include deleting merge styles as well as creating new ones and setting current text and dim text styles. One of my top 5 downloads!
    http://www.theswamp.org/index.php?topic=17659.0;all
    Earth
    9,804
    Thank you for posting this. This is a very nice routine!
    R.K. McSwain | CAD Panacea |
  1. Merge Text Styles ie LAYMRG but for text styles
    By dustin692884 in forum AutoLISP
    Last Post: 2018-05-01, 11:59 AM
  2. Merge Text Styles to a Selected Text Style
    Last Post: 2013-05-16, 01:58 PM
  3. VBA.NET Routine to Merge Text Styles
    By chillme1 in forum Dot Net API
    Last Post: 2011-02-24, 11:27 AM
  4. Sharing standard Dimension styles, text styles, hatch patterns, etc
    By dhavalpatel_us337373 in forum AutoCAD General
    Last Post: 2007-02-02, 08:34 PM
  5. Merge Text Styles
    By BCrouse in forum AutoLISP
    Last Post: 2005-04-26, 10:05 PM
Tags for this Thread
