MikeMcCulley.RLS
This is right out of the Navisworks 2017 exporters help file under CAD Preview.
"The ARX plugin also enables you to walk through your model in real time inside a dockable Navigator window directly in the AutoCAD interface.
You can easily import and export viewpoints between Navigator and AutoCAD, and explore the models that you are building.
NOTE:The Autodesk Navisworks Navigator is provided for products based on AutoCAD 2008™ and above."
This is the function I am looking for. Worked fine in 2016 version.
MMc
