Thread: Trouble with 2017 install
    2007-09
    Granville, IL
    7
    Question Trouble with 2017 install
    Our office just received a couple new workstation towers and I am having problems installing 2017 Product Design Suite Premium. I keep getting the following errors, has anyone seen these before?
    New Workstations
    Windows 10 Pro
    i7-6700 CPU @ 3.40GHz
    32GB Ram
    Quatro K2200
    Any help would be greatly appreciated.
    Earth
    9,804
    Default Re: Trouble with 2017 install
    If you don't get any assistance here, head over to the Installation forum at autodesk and ask.
    There is probably a larger audience there.
    R.K. McSwain | CAD Panacea |
    2009-11
    5,719
    Did you Unblock the downloaded installer files before extracting them? Right click each file, select Properties, check Unblock, click OK for all of them, then extract.
    Where is drive E: located, Network?
    Have you tried running the installer from either local disk (C:\Autodesk is default?), or USB?
    Cheers
    Computer Specs:
  1. 2017: Revit 2017 is Available Now
    By Steve_Stafford in forum Revit - Platform
    Last Post: 2016-12-03, 06:24 AM
  2. 2017: autocad 2017
    By agaven34734397 in forum AutoCAD General
    Last Post: 2016-08-31, 06:29 PM
  3. 2017: Revit 2017 install error message
    By salaaaah_2010729743 in forum Revit MEP - Families
    Last Post: 2016-06-11, 03:53 PM
  4. 2017: Install problems with Revit MEP 2017
    By mickaeL_renauD in forum Revit MEP - General
    Last Post: 2016-05-27, 01:09 PM
  5. 2011: ACA 2010 - Install express tools after install
    By shane.249457 in forum ACA General
    Last Post: 2010-07-14, 03:15 PM
Tags for this Thread
