Thread: closed filled arrow head bug when creating new multileader style
    2013-01
    18
    Default closed filled arrow head bug when creating new multileader style
    Hello and happy new year
    when i ran my program i got this message
    eInvalidInput
    at
    Autodesk.AutoCAD.ApplicationServices.Core.Application.SetSystemVariable(String name, Object value)
    at this line
    Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("DIMBLK", "_Closedfilled")
    but it's happened only with the closed filled arrow and works well with ALL other types of the arrowhead
    like _Dot, _Closedblank,.......
    here is the code
    ' Make the arrow head as _Closedfilled.
    Dim mldstyle As New MLeaderStyle()
    Dim blockTable As BlockTable = tr.GetObject(db.BlockTableId, OpenMode.ForRead)
    If (Not blockTable.Has("_Closedfilled")) Then
    ' load the "_DOT" block definition
    End If
    mldstyle.ArrowSymbolId = blockTable("_Closedfilled")
    How to fix it?
    and if the answer is to load it at the begin, then how to do it?
    i'm needing helps
    thank you
    Turlock, CA
    6,397
    Default Re: closed filled arrow head bug when creating new multileader style
    Can you change it manually? Does the block exist in the dwg?
    C:> ED WORKING....
  1. Creating Multileader Style using LISP
    By vladimir.karatsupa982899 in forum AutoLISP
    Last Post: 2018-03-08, 05:44 PM
  2. Modify Multileader Arrow Size
    By Borgster in forum AutoLISP
    Last Post: 2012-01-09, 10:28 PM
  3. Replies: 10
    Last Post: 2010-03-11, 12:49 PM
  4. Multileader arrow disappears
    By noah in forum AutoCAD General
    Last Post: 2008-03-26, 11:22 AM
  5. Replies: 3
    Last Post: 2004-08-13, 03:48 PM
