AutoCAD built into Inv IDW
Summary: AutoCAD built into Inv IDW
Description: Basically there would be an Autocad button on the Inv ribbon. When you press this it would open up AutoCAD within Inv IDW. You would have all features of AutoCad like properties menu, command line, dynamic block, geometry (lines, circles, polylines....), dimensions(based on Inv dimensions). All Autocad commands would work when using this feature.... Your page setup would still be the same as it currently is in Inv IDW and you would still need to click on page 2 in the tree menu if wanted to draw on page 2.
Product and Feature: Inventor - API
Submitted By: wrmarshall on 01/13/2017
- You may not post replies
- You may not edit your posts
Forum Rules
