All,
This is driving me crazy. I have been following the post:
https://knowledge.autodesk.com/searc...7A763-htm.html
After trying several variations using the Intall Section of the ini and using the format Update=section|setting;section|setting;section|setting... I can't get user's settings to update. In fact, the only way I can seem to force a change is to delete the user's Revit.ini and then replace the Revit.ini in the All User settings and rather than use the Update as directed, simply set options in the install section using the format [Section] Setting=setting.
This is a flawed work around in that user's lose other settings. I am attaching my most recent file which is set up for Revit 2016 as well as the Update section which failed completely.
Any thoughts or humorous stories of related experience would be appreciated.
Jeff
