Results 1 to 6 of 6
Thread: upgrading to 2018 Civ3D
    2009-11
    Raleigh, NC
    941
    Default upgrading to 2018 Civ3D
    I am hearing that 2017 Civil 3D will not support Civil 3d proxy objects from any previous versions.
    Is this true?
    What will be a simple process for transition with so many company projects done in 2016 hen we upgrade to 2018 here in very short time?
    TN/KY Area
    1,640
    Default Re: upgrading to 2018 Civ3D
    Quote Originally Posted by tim_newsome View Post
    Is this true?
    Those that know can't say yet, those that say don't know. Still a few weeks/months before it gets released.
    Cairo - no, not Illinois
    5,069
    Historically, forwards compatibility has been maintained. Backwards --- not so much. Seems like the folk in the Adesk C-Suite are not fans of interoperability, even with their own products.
    If suddenly Autodesk eliminates the forward compatibility path, and requires all users to recreate their C3D objects from scratch.... there would be a new C-Suite rather quickly.
    (and as Murph noted, I don't _know_, thus I can say )
    Earth
    9,804
    Did you mean to say 2018, above?
    Because 2017 is not backwards compatible with earlier versions of C3D. No secret there.
    R.K. McSwain | CAD Panacea |
    2009-11
    Raleigh, NC
    941
    I am not sure if my question (second line) was read before replying. I will try to reword it if it did not make since.
    Once I upgrade to 2018 will the 2016 Civ3D 2016 dwg proxy objects translate to version 2018 just by opening them with 2018?
    Earth
    9,804
    I don't know what you mean by "2016 Civ3D 2016 dwg proxy objects".
    Are you talking about general Civil 3D objects such as cogo points, surfaces, corridors, etc.?
    If so, if they follow the same trend of the last dozen years or so, then yes. Drawings and object have always been forward compatible. But only backwards compatible in releases 2013-2016.
  1. Replies: 0
    Last Post: 2013-04-05, 11:39 AM
  2. Upgrading to 64 bit O/S?
    By ccowgill in forum AutoCAD General
    Last Post: 2009-07-18, 01:40 PM
  3. Upgrading
    By tcdavis in forum DV - The 3rd Dimension
    Last Post: 2008-03-31, 08:14 PM
  4. Upgrading ADT?
    By StephenJ in forum ACA General
    Last Post: 2005-12-23, 03:06 AM
  5. Windows XP - Upgrading to XP
    By joe.n in forum Operating Systems
    Last Post: 2005-09-22, 03:04 PM
