Thread: help user upgrade from c3d 16 to c3d 17
    2012-08
    20
    Default help user upgrade from c3d 16 to c3d 17
    The company I work at gave me 2017 when I started....
    other users are worried about the upgrade.
    does autodesk or Augi have an upgrade manual for the user?
    we will have IT do the upgrade, they are worried about their menus etc.
    I already know about the arg file, anything else they should do to make it easier on themselves.
    Earth
    9,805
    Default Re: help user upgrade from c3d 16 to c3d 17
    1. Know that C3D 2016 and 2017 are not compatible. The DWG file format is the same, but the C3D objects are not.
    2. Keep both versions installed, and finish up existing projects in 2016.
    3. Migrate user created menu data to a separate CUIX menu in 2016 before upgrading. Then that menu file can be attached as a partial menu in both versions. I would avoid AutoCAD's migration tools if possible.
    HTH
    R.K. McSwain | CAD Panacea |
  1. 2014: New Keynote/Tag User - Can User input be added.
    By jason.miller681034 in forum Revit - Platform
    Last Post: 2014-11-26, 05:13 PM
  2. Replies: 0
    Last Post: 2008-08-25, 02:03 PM
  3. Upgrade the Upgrade Utility
    By ctc in forum Revit Architecture - Wish List
    Last Post: 2006-09-26, 01:58 PM
  4. Replies: 2
    Last Post: 2006-03-27, 08:20 AM
  5. How do I change my Forum User Name (user ID)
    By Mike.Perry in forum Forum Tips & Tricks (Read only)
    Last Post: 2006-02-13, 09:28 PM
