Thread: Help with contour line widths
    2004-06
    Slidell, Louisiana
    972
    Default Help with contour line widths
    having a bear of a time trying to figure out how line widths/weight works in map 3d. i have a themed map from which i have created a contour layer.
    the text is showing up okay, but the contours are not. when i go to print, they display fine on screen, but when it comes out of the print they are so thin and light that you can
    barely see them at all. i'm on a 500' scale on a letter size sheet. i'v tried tweeking the style. if i change the line thickness to anything other than 0, the lines are huge and fill the entire viewport. also have changed the width to no avail.
    any suggestions or help?
    2014-08
    448
    Default Re: Help with contour line widths
    Hi
    it depends are you plotting by color or line thickness. You also should check you surface style the contour line thickness maybe controlled here if you are controlling the plot of the contour by the layer set the style to plot by layer
    TN/KY Area
    1,640
    Are these contour lines Map features (data connect) or autocad plines? If they are feature ojbects are you setting the size to use Device or Map?
    2004-06
    Slidell, Louisiana
    972
    they were created from a data connect to a geotiff and the style line is set to device with units on millimeters.
    TN/KY Area
    1,640
    Try setting it to Map and set the size to 500 (or your plot scale) You may need to play around with the size to get it right.
  1. Printing with scalable line widths
    Last Post: 2013-11-26, 02:28 PM
  2. Plot with Scaled Line widths
    Last Post: 2012-12-15, 05:07 AM
  3. Access Line Weights/Widths through the API?
    By aireq303 in forum Revit - API
    Last Post: 2011-09-19, 11:55 PM
  4. 2011: line widths
    By rmk in forum AutoCAD General
    Last Post: 2011-03-29, 01:14 PM
  5. why does the imported contour line NOT following the contour line!!!
    By Richard McCarthy in forum Revit Architecture - General
    Last Post: 2004-10-25, 12:34 PM
