Can you have more than one description key set and if so, what determines which key set gets applied to the points?
Or is it just the fact that the code is different and C3D applies all key sets if the code applies?
I have a handful. If you right-click Description Key Sets and select Properties… it brings up a box for Description Key Sets Search Order. You simply select one and move it up or down with the arrows on the right.
So it uses the hierarchy approach.
thanks Tom.
did you see my other thread about converting N 00°00'00"E to read NORTH without having to manually edit each one.
have it annotate NORTH automatically. i'm sure there's some coding or command that can make that happen.
