Thread: worksharing to windows network vis vpn?
    2004-06
    335
    Default worksharing to windows network vis vpn?
    Two firms are going to be working on a Revit project simultaneously using worksharing, each from their own office. Is it as simple as having the central model hosted on one of the firm's Windows network and the other firm be given network access to a shared folder via vpn? Thx.
    2006-05
    Seattle, WA
    180
    Default Re: worksharing to windows network vis vpn?
    Sounds like a bad idea, especially if both firms are working at the same time. Although it is technically possible, users may experience general model slowness at minimum. At worse, this can corrupt the model.
    Recommend using Revit Server or Autodesk BIM 360 Collaboration for Revit (C4R). Revit Server requires some IT support and a VPN. C4R is Autodesk's cloud solution, but it involves a monthly fee for each user.
    2004-06
    335
    Thanks. The hosting firms IT guy just said that worksharing will work simply by having the central file on their Windows network. I guess we will see. If it doesn't work as needed, I suppose we could always move the project to A360.
  1. 2011: AutoCAD LISP on the Network using Windows 7 = Lag
    By ronsarlo in forum AutoCAD General
    Last Post: 2011-04-29, 12:04 AM
  2. AutoCAD 2010 in Windows 7 Won't Allow Network Navigation
    By mark.81576 in forum CAD Management - General
    Last Post: 2010-02-04, 05:29 PM
  3. Replies: 12
    Last Post: 2007-07-06, 11:33 PM
  4. Replies: 1
    Last Post: 2006-12-13, 03:53 PM
  5. Project Navigator in Windows Network
    By chammer in forum ACA General
    Last Post: 2004-09-23, 04:02 PM
Tags for this Thread
