Thread: Need help with intergrating new Grade into Existing contour lines. WILLING TO PAY
    2017-02
    Default Need help with intergrating new Grade into Existing contour lines. WILLING TO PAY
    Hello, I'm looking for some help in integrating new topography into existing contour lines and I have no idea how to go about doing it. I don't know how to work Civil 3D or even if that's what I need to achieve this. I'm willing to pay someone to do this for me or to help me figure out how to do it. I will attach a PDF of the site I'm talking about. In the end I want to be able to generate a surface using the contours and have it include the proposed site modification. I have the existing contour lines at their proper elevations but the new grade modifications is just a flat dwg.
    Hope someone can help and I apologize if this isn't the right place to ask this
    2015-10
    Central New Jersey
    439
    Default Re: Need help with intergrating new Grade into Existing contour lines. WILLING TO PAY
    I see two possible ways to go.
    #1 - Create an 'Existing' surface, add the existing contours to define it. Create a 'Modified' surface. Add elevations (z values) to the line work of the modified grading. Add this line work to the surface as contours to define it. Create a third surface, 'Final' surface. First paste the Existing surface into it and then paste in the Modified. The result will be a composite of the two.
    #2- Clip the existing contours at the limits of the modified grading. Add elevations values to the modified grading line work. Create a 'Final' surface and add the existing contours and modified grading lines as contour data to define the surface.
    2017-01
    Hi Jaramillo, I have a few questions for you. Is the original file a civil 3d file that already has a surface in it? What format are the new contour lines? 3d polylines? This is a quick thing to do if these are true. If you attach the data, I can take a look at it for you.
  1. Contour Lisp to create contour lines from TIN 3D Faces
    By Sameer Ahmed in forum AutoLISP
    Last Post: 2016-06-11, 07:28 PM
  2. 2016: Topography Contour Labels only on some Contour Lines
    By Duncan Lithgow in forum Revit Architecture - General
    Last Post: 2015-11-19, 09:56 AM
  3. Balance Grade to an existing surface
    By dchope in forum AutoCAD Civil 3D - Grading
    Last Post: 2014-08-29, 08:41 PM
  4. Existing Grade Linetype
    By jmoore.218473 in forum AutoCAD Civil 3D - Profiles
    Last Post: 2009-06-05, 01:16 AM
  5. Existing contour lines
    By kjgiant in forum Revit Architecture - General
    Last Post: 2005-12-29, 09:48 PM
