Results 1 to 7 of 7
Thread: Translucent Wipeout
    2015-10
    Central New Jersey
    439
    Default Translucent Wipeout
    We're all familiar with the use of wipeouts to completely block out anything that is behind it based on its draw order, however, apparently you can also give it a translucency such that it it only partially obscures the items behind it. I happened upon it earlier this week. I'm not quite sure what to do with it yet but I thought I'd share it with others.
    I suppose one could place it within a block behind its contents, set the translucency to 50, and it would '50% screen' existing items behind where the block of new items was place. One could add it to an area of a drawing, set a translucency, then set the draw order of items to be above or below it to screen those items, but only when they crossed into that partial wipeout area.
    9,804
    Default Re: Translucent Wipeout
    A Good tip. Thanks.
    Cairo - no, not Illinois
    5,069
    yes, thanks. I've got a couple of scenarios where that will be useful. Now if we could just do that with C3D Labels, or Mtext/Dim backgrounds....
    2016-02
    Chantilly, VA
    8
    Where is this feature , I'm using 2016 C3D and I do not see this feature....is it in 2017?
    9,804
    No, it works in all versions since transparency was introduced, which was AutoCAD 2011 I believe.
    Make sure you have transparency enabled (TRANSPARENCYDISPLAY = 1)
    2017-11
    Where do I ask questions?
    2015-10
    Central New Jersey
    439
    You can ask your question right here.
  1. wall with translucent panels
    By olson in forum Revit Architecture - General
    Last Post: 2008-12-11, 05:31 PM
  2. Translucent hatch patterns
    By mserapiglia in forum Impression - General
    Last Post: 2008-07-10, 09:49 PM
  3. Civil 3D 2007 - Wipeout does not wipeout Objects in a floating viewport
    By youngrl501483 in forum AutoCAD Civil 3D - General
    Last Post: 2007-03-14, 09:47 PM
  4. Translucent Shaded Views
    By gregcashen in forum Revit Architecture - Wish List
    Last Post: 2005-08-19, 09:02 PM
  5. translucent coloring
    By Maverick91 in forum AutoCAD General
    Last Post: 2004-09-24, 04:02 PM
