Results 1 to 7 of 7
Thread: line direction
    2004-06
    Slidell, Louisiana
    972
    Default line direction
    What setting or sysvar would cause a line to be drawn in the opposite direction? i.e. when I type the command line, @100<N90°E (due East) it draws the line due west.
    units or set for surveyors units. direction: east is 0: usc is world. ucs icon has the y straight up and x is to the right.
    2015-05
    West Des Moines
    306
    Default Re: line direction
    Have you ran an annotation label on the line you draw to see what it says? Since you're attempting to draw N90°E, but getting the opposite direction I'm curious if the direction is still stated as being N90°E because that would probably mean that your DWG is borked. And on that note have you tried in other DWGs or have other users tried in the DWG? I can't think of why there'd be an opposite system variable, but that doesn't mean it wouldn't be there.
    Earth
    9,804
    Can you post this drawing (strip everything out if needed) ?
    R.K. McSwain | CAD Panacea |
    2004-06
    Slidell, Louisiana
    972
    Unfortunately i don't have the drawing in house. it's a friend of mine who's taking some drafting classes and she has the drawing on her laptop.
    her assignment was to draw a survey parcel using bearings and distances (vanilla autocad, not C3D). I haven't seen it first hand, just going by what she is telling me.
    Cairo - no, not Illinois
    5,069
    yeah, my first thought is that W and E are next to each other on the keyboard,, and there's simply a typo happening. my personal bane is the I and O being so close together
    TN/KY Area
    1,640
    See attached.
    Active Member ervin_david's Avatar
    2004-07
    Southeastern USA
    98
    The line is drawn relative to the coordinate system. Make sure the USC is set to World Coordinate System. At the command line, type,
    ucs enter enter
    plan enter enter
    Then draw the line.
  1. 2012: Line by direction command
    By trevor.hatch597223 in forum AutoCAD Civil 3D - Survey
    Last Post: 2013-07-29, 09:41 PM
  2. This breaks line in only one direction
    By jgratton in forum AutoLISP
    Last Post: 2009-11-12, 09:11 PM
  3. Flip line direction
    By dasmith in forum AutoCAD Civil 3D - General
    Last Post: 2009-07-25, 12:44 PM
  4. Line has inaccurate direction
    By dfriesen in forum Revit Architecture - General
    Last Post: 2005-10-19, 08:03 PM
  5. Line has innacurate direction
    By markl.70662 in forum Revit Architecture - General
    Last Post: 2005-06-01, 09:37 PM
