Thread: Using mvba file
    2016-04
    Default Using mvba file
    Can you use a .mvba file to run and load in autocad 2014?? This file is from Microstation V8i. Can anyone please help me???
    6,419
    Default Re: Using mvba file
    For two reasons the answer is No. First, acad uses dvb files and second the code would not work even if the file would load. AutoCAD's API (application programming interface) is totally different from Microstation's.
    LinkedIn
  1. Replies: 7
    Last Post: 2013-11-16, 11:44 PM
  2. 2014: Revit reporting Central File is not available, no one else is in file, can't save, won't create local file
    By patricks in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2013-10-03, 10:31 PM
  3. Replies: 1
    Last Post: 2008-10-14, 02:32 AM
  4. Replies: 0
    Last Post: 2008-10-13, 10:20 PM
  5. Copy from individual REVIT file to workset file (shared file)
    By kkansara in forum Revit Structure - General
    Last Post: 2007-08-06, 05:02 PM
