Hi,
Try this! Adjust variable in lisp if it is not correct.
(defun c:DimPline ( / adoc space obj_dim obj_angdim height_dim pl ent obj dxf_ent ll ur dir_pt base_pt dir_ang last_pt pr_pt lst_pt nw_obj)
(vl-load-com)
(setq
adoc (vla-get-activedocument (vlax-get-acad-object))
space
(if (= 1 (getvar "CVPORT"))
(vla-get-paperspace adoc)
(vla-get-modelspace adoc)
obj_dim (vla-add (vla-get-Dimstyles adoc) "DIMPLINE")
obj_angdim (vla-add (vla-get-Dimstyles adoc) "DIMANGPLINE")
(vla-put-activedimstyle adoc obj_dim)
(initget 6)
(setq height_dim (getdist (getvar "VIEWCTR") (strcat "\nHeight of dim text <" (rtos (getvar "DIMTXT")) ">: ")))
(if height_dim (vla-setvariable adoc "DIMTXT" height_dim) (setq height_dim (getvar "DIMTXT")))
(mapcar '(lambda (data_list / ) (vla-setvariable adoc (car data_list) (cdr data_list)))
(list
(cons "DIMPOST" "")
(cons "DIMAPOST" "")
(cons "DIMSCALE" 1.0)
(cons "DIMASZ" (getvar "DIMTXT"))
(cons "DIMEXO" (/ (getvar "DIMTXT") 2.54))
(cons "DIMDLI" 0.38)
(cons "DIMEXE" (/ (getvar "DIMTXT") 2.54))
(cons "DIMRND" 0.0)
(cons "DIMDLE" (/ (getvar "DIMTXT") 2.54))
(cons "DIMTP" 0.0)
(cons "DIMTM" 0.0)
(cons "DIMCEN" 0.09)
(cons "DIMTSZ" 0.0)
(cons "DIMALTF" 25.4)
(cons "DIMLFAC" 1.0)
(cons "DIMTVP" 0.0)
(cons "DIMTFAC" 1.0)
(cons "DIMGAP" 0.09)
(cons "DIMALTRND" 0.0)
(cons "DIMTOL" 0)
(cons "DIMLIM" 0)
(cons "DIMTIH" 0)
(cons "DIMTOH" 0)
(cons "DIMSE1" 0)
(cons "DIMSE2" 0)
(cons "DIMTAD" 1)
(cons "DIMZIN" 0)
(cons "DIMALT" 0)
(cons "DIMALTD" 2)
(cons "DIMTOFL" 1)
(cons "DIMSAH" 0)
(cons "DIMTIX" 0)
(cons "DIMSOXD" 0)
(cons "DIMCLRD" 3)
(cons "DIMCLRE" 1)
(cons "DIMCLRT" 3)
(cons "DIMADEC" 2)
(cons "DIMDEC" 4)
(cons "DIMTDEC" 4)
(cons "DIMALTU" 6)
(cons "DIMALTTD" 2)
(cons "DIMAUNIT" 0)
(cons "DIMFRAC" 2)
(cons "DIMLUNIT" 4)
(cons "DIMDSEP" ".")
(cons "DIMTMOVE" 0)
(cons "DIMJUST" 0)
(cons "DIMSD1" 0)
(cons "DIMSD2" 0)
(cons "DIMTOLJ" 1)
(cons "DIMTZIN" 0)
(cons "DIMALTZ" 0)
(cons "DIMALTTZ" 0)
(cons "DIMUPT" 0)
(cons "DIMATFIT" 3)
(cons "DIMBLK" "_ARCHTICK")
(vla-copyfrom obj_dim adoc)
(vla-setvariable adoc "DIMBLK" ".")
(vla-copyfrom obj_angdim adoc)
(princ "\nSelect polylines: ")
(while (null (setq pl (ssget '((0 . "LWPOLYLINE"))))))
(repeat (setq n (sslength pl))
(setq
ent (ssname pl (setq n (1- n)))
obj (vlax-ename->vla-object ent)
dxf_ent (entget ent)
lst_pt (mapcar 'cdr (vl-remove-if-not '(lambda (x) (= (car x) 10)) dxf_ent))
(vla-GetBoundingBox obj 'll 'ur)
(setq
ll (safearray-value ll)
ur (safearray-value ur)
dir_pt (mapcar '* (mapcar '+ ll ur) '(0.5 0.5 0.5))
base_pt (mapcar '(lambda (a b) (* (+ a b) 0.5)) (car lst_pt) (cadr lst_pt))
dir_ang
(if (< (- (angle base_pt (polar base_pt (+ (angle (car lst_pt) (cadr lst_pt)) (* 0.5 pi)) (getvar "DIMTXT"))) (angle base_pt dir_pt)) pi)
(* pi 0.5)
(* pi 1.5)
(if (not (zerop (logand 1 (cdr (assoc 70 dxf_ent)))))
(setq last_pt (car lst_pt) lst_pt (cons (last lst_pt) lst_pt) pr_pt (last lst_pt))
(setq pr_pt nil)
(while (cdr lst_pt)
(setq nw_obj
(vla-addDimAligned
space
(vlax-3d-point (car lst_pt))
(vlax-3d-point (cadr lst_pt))
(vlax-3d-point (mapcar '(lambda (a b) (* (+ a b) 0.5)) (car lst_pt) (cadr lst_pt)))
(vlax-put nw_obj 'TextPosition (polar (vlax-get nw_obj 'TextPosition) (+ (angle (car lst_pt) (cadr lst_pt)) (+ dir_ang pi))(* 3.25 (getvar "DIMTXT"))))
(if pr_pt
(progn
(vla-put-activedimstyle adoc obj_angdim)
(setq nw_obj
(vla-AddDimAngular
space
(vlax-3d-point pr_pt)
(vlax-3d-point (polar (car lst_pt) (angle (car lst_pt) dir_pt) (* 5.0 (getvar "DIMTXT"))))
pr_pt (car lst_pt)
(setq pr_pt (car lst_pt))
(setq lst_pt (cdr lst_pt))
(if pr_pt
(setq nw_obj
(vla-AddDimAngular
space
(vlax-3d-point last_pt)
(vlax-3d-point (polar (car lst_pt) (angle (car lst_pt) dir_pt) (* 3.25 (getvar "DIMTXT"))))
pr_pt (car lst_pt)
(princ)
