So typically we haven't had to use elliptical pipe much, if we do it is just a pipe or two, however on this project it is 2/3 of our pipes. So in the pipe table when size is listed it appears as ? because our pipe table is set to read inner diameter, the round pipe shows up fine. Now I saw you can do a height and width of pipe label which works but then the round pipe read as ? soooooo my question is can there be an expression or an if/then statement written and put in the table? Or does anyone have suggestions on handling this? Our typical way of handling for the one or two pipes is just mask text over the table and callout but there are too many to do that this time.
