Hello!
I start learn Revit.
I want to project building. I will use a sandwich-panels. Which tip is the best to create sandwich-panels?
Hello!
Hello
I did two small jobs with sandwich panels
("SIPS" Structural Insulated Panels = Plywood-Expanded Polystyrene-Plywood. Good Insulation)
I had to import the hexagonal hatch pattern from AutoCAD. Otherwise it was easy to make a wall-type for such panels.
I hope this is helpful...
If they are truly panels, I would create the wall type and host them in a curtain wall grid. this way you have the actual panel joints.
Other option would be to create a curtain wall panel that mimics it. But hosting by hosting a wall in a curtain you can host a window, opening or door in it.
Thank you very much!
Medicine-microbiology laboratory building photo.
Wonderful, beautiful sandwich panels!
