Thread: How to install dotNet tempplates
    Default How to install dotNet tempplates
    Hi all
    I've recently tried to install the dotNet API for AutoCAD 2014 onto my computer with VS 2015 (community). Through the process I've downloaded the self extracting exe from the Autodesk website and have ran the extract. Unfortunately that's as far as I've managed to get. When I open VS the templates are not available in the new project templates list.
    Is there another step required to get the templates to appear?
    Programming Moderator BlackBox's Avatar
    Default Re: How to install dotNet tempplates
    Welcome to AUGI.
    I experienced this issue myself a while back; see if this old Autodesk forum thread helps:
    Please note the link in the post #7 edit to add.
    "Potential has a shelf life." - Margaret Atwood
    AutoCAD, and Civil 3D Certified Professional | Autodesk Authorized Developer
    1 members found this post helpful.
    You can find AutoCAD 2013 to 2017 plugin project templates for Visual studio 2015 here.
    These are basic templates which automatically launch AutoCAD and load the DLL when starting Debug (F5).
    Save the ZIP(s) file(s) you need in the Visual Studio project Template folder (default: .\Documents\Visual Studio 2015\Templates\ProjectTemplates).
    If acad.exe path is not C:\Program Files\Autodesk\AutoCAD 2014 or if the AutoCAD libraries (accormgd.dll, acdbmgd.dll, acmgd.dll) are not in C:\ObjectARX 2014\inc, change these paths in the AutoCAD2014Plugin.csproj which is in the ZIP file.
  1. DotNet Visual Lisp
    By dmarcotte4 in forum API Wish List
    Last Post: 2012-09-08, 06:32 PM
  2. Installing ACAD 2011 dotNet Wizards
    By sec.bvba520978 in forum ARX
    Last Post: 2011-06-22, 08:34 PM
  3. VBA2DotNet or DotNet
    By EddieS in forum Dot Net API
    Last Post: 2010-10-25, 11:19 PM
  4. dotNet Programming for Cad and Revit
    By pgregersen2 in forum ATP Course Wishlist
    Last Post: 2008-06-05, 02:11 PM
  5. Combine dwfs with DotNet?
    By mweaver in forum Dot Net API
    Last Post: 2007-10-29, 10:53 AM
Tags for this Thread
