Thread: Room areas to fill niches
    All AUGI, all the time Duncan Lithgow's Avatar
    2006-09
    Denmark
    621
    Default Room areas to fill niches
    Sometimes I see people asking how to make the area of a room go all the way into a window niche, instead of stopping at the line fo the wall above.
    This can be done in two ways that I know of:
    * by putting your window into a special piece of wall which has the desired depth in the 'host' wall
    * by removing the section of wall and replacing it with a Curtain Wall
    I hope that helps someone!
    2015-10
    2
    Default Re: Room areas to fill niches
    Quote Originally Posted by Duncan Lithgow View Post
    Good tip! Thanks!
  1. 2016: How to include hidden areas in cut and fill volume.
    By Toni@Simpkins-Costelli in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2016-03-24, 04:24 PM
  2. hatching cut and fill areas in section view
    Last Post: 2013-11-19, 08:37 PM
  3. windows in fill areas
    By lila in forum Revit Architecture - General
    Last Post: 2007-06-21, 04:13 AM
  4. Color Fill, Areas or Rooms
    By phyllisr in forum Revit Architecture - General
    Last Post: 2006-11-14, 02:39 PM
  5. Cut and fill areas on cross sections simultaneously
    By aion in forum Civil 3D - Civil Design Companion - General
    Last Post: 2005-03-28, 05:20 PM
Tags for this Thread
