Thread: void parametric array
    2009-02
    Default void parametric array
    Hi.
    I am trying to create a beam with a parametric void array but the void is not cutting the extrusion, any ideas?
    Thanks
    Eoghan
    2010-10
    Chicago, IL
    376
    Default Re: void parametric array
    Make the hole pattern as a separate face based family, cut the host and nest it into your beam family, then array.
  1. Void in Array Problem
    By iankids in forum Revit Architecture - Families
    Last Post: 2010-07-26, 05:07 AM
  2. void parametric array
    By t1.shep in forum Revit Architecture - Families
    Last Post: 2010-03-29, 06:02 PM
  3. New solids in array is not cut by void
    By Arndt in forum Revit Architecture - Families
    Last Post: 2010-01-11, 02:51 PM
  4. Using a void array to parametically cut geometry?
    By p.alvito in forum Revit Architecture - General
    Last Post: 2009-01-31, 08:54 AM
  5. Parametric Drawer Front with array (problems controling array)
    By robert.manna in forum Revit Architecture - Families
    Last Post: 2007-04-04, 05:17 AM
