Results 1 to 8 of 8
Thread: Default AutoCAD 2017 plot color lineweights
    2017-03
    4
    Question Default AutoCAD 2017 plot color lineweights
    What are the "Default" values of AutoCAD plot color lineweights?
    2004-08
    Hartford, Michigan
    3,194
    Default Re: Default AutoCAD 2017 plot color lineweights
    https://knowledge.autodesk.com/suppo...D5130-htm.html
    0.25mm according to the above article.
    Christopher T. Cowgill, P.E.
    Autodesk Expert Elite
    AEC Collection Civil 3D 2019
    Windows 10
    2017-03
    4
    Allow me to clarify, I know that the default AutoCAD color plot file, the line weights assigned for the following colors:
    1=0.18mm, 0.0071"
    2=.025mm, 0.0098"
    3=0.35mm, 0.0138"
    4=.035mm, 0.0138"
    5=0.50mm, 0.0197"
    6=1.00mm, 0.0394"
    7=1.40mm, 0.0551"
    8=0.35mm, 0.0138
    9=0.20mm, 0.0079"
    10=0.18mm, 0.0071"
    I would like to know what the default assigned values are for the rest of the colors up to 255.
    2004-08
    Hartford, Michigan
    3,194
    Actually, on mine, there are no default values at all, other than use Object Lineweight, for all 255 colors.
    you can find the default acad.ctb file here:
    C:\Users\*username*\AppData\Roaming\Autodesk\AutoCAD 2017\R21.0\enu\Plotters\Plot Styles
    Windows 10
    2017-03
    4
    I reprinted using a large format plotter instead of a printer and now I see, it is not a lineweight difference, but a grayscale difference creating an optical illusion.
    On that note, I will change my question.
    Is it possible to determine the grey color or light-dark value if any associated with each color?
    2004-08
    Hartford, Michigan
    3,194
    unfortunately, no. the grey scale is directly associated to the actual color of the object, so yellow is really light, red is darker, blue is super dark, white would be black, etc.
    Now on that note, you can actually change the ctb file to make everything black/grey. but you would have to set up everything to start with manually.
    What is it you are trying to achieve? Perhaps that will help get to your ultimate solution more quickly.
    Windows 10
    2017-03
    4
    I just started working at a new company and am instituting a set of drawing standards to get all of the drafter's drawings to look the same, which the company has never had before. I'm trying to start clean and fresh without having to spend thousands on getting ANSE or any other standards. I was trying to figure out what AutoCAD uses to minimize the amount of changes I will need to make.
    2004-08
    Hartford, Michigan
    3,194
    Ok, that simplifies it.
    If you are going to use color dependant plot styles (CTB) then what you can do is establish within the ctb file what you want to use. you should be able to do a lot with a few different colors. we used to use the first 16, then decided we wanted to use a few other colors, so we expanded it. I can provide a copy of our old ctb file if you'd like a place to startoff.
    Windows 10
  1. Image Button color in 2017 not working
    By CadDog in forum AutoLISP
    Last Post: 2016-12-06, 07:29 PM
  2. 2010: AutoCAD Table Linked to Excel, Text Does Not Plot by Color, is too light
    By rkugl90701234 in forum AutoCAD Tables
    Last Post: 2015-06-12, 04:27 PM
  3. AutoCAD 2005 - Controlling Lineweights at Plot time
    By clark123 in forum AutoCAD Plotting
    Last Post: 2006-12-06, 03:13 AM
  4. lineweights won't plot
    By vanderloo5 in forum AutoCAD Plotting
    Last Post: 2004-12-08, 04:27 AM
  5. Can't plot lineweights
    By ssharp in forum AutoCAD Plotting
    Last Post: 2004-09-27, 07:50 PM
