Thread: DWGUNITS and system varibles
    2006-04
    466
    Default DWGUNITS and system varibles
    Are there any system varibles associated with the DWGUNITS command?
    2004-08
    Iron Station, NC
    3,198
    Default Re: DWGUNITS and system varibles
    https://knowledge.autodesk.com/suppo...-INSUNITS.html
    Based on this article, it sounds like -dwgunits is a system variable only used in vertical products. I would assume anything that has to do with units would be related.
    2006-04
    466
    thanks ccowgill! INSUNITS might do the job.
    2006-04
    466
    I like light years
    2003-07
    559
    To quote a few
    (SETVAR "LUNITS" 2)
    (SETVAR "ANGBASE" 0.0)
    (SETVAR "ANGDIR" 0)
    (SETVAR "LUPREC" 0)
    (SETVAR "AUNITS" 0)
    (SETVAR "AUPREC" 0)
  1. Make electrical system, like pipe- and duct system.
    Last Post: 2012-08-01, 06:53 AM
  2. Replies: 0
    Last Post: 2011-01-25, 05:59 AM
  3. Image Files created on a 32 bit system not working on a 64 bit system?
    By scott.epp in forum AutoCAD Civil 3D - General
    Last Post: 2010-10-05, 09:59 PM
  4. using the beam system tag on beams that wern't created with the system tool
    By khanson-3b in forum Revit Structure - General
    Last Post: 2006-08-16, 02:47 PM
  5. Ruled Curtain System: Can't change System Panel
    By Chad Smith in forum Revit Architecture - General
    Last Post: 2003-09-30, 09:15 PM
