Thread: New to AutoCAD Architecture
    2016-12
    2
    Default New to AutoCAD Architecture
    Hi,
    I'm new to AutoCAD architecture and was wondering if anyone has run into a couple things.....
    1. On layer properties manager, when opening a file, making a block, etc. the "icons" are extremely small, does anyone know how to make them larger? Also, when I go to open a file the "file path" location info is cut off, meaning I see the top half of the words and the bottom is gone.
    2. Tool pallets/buttons of the past...are they obsolete now?
    I'm still trying to figure everything out, first day and some wicked deadlines are calling my name!
    Pam
    100 Club a_meteni's Avatar
    2002-12
    Cairo
    174
    Default Re: New to AutoCAD Architecture
    1. check this thread that are related to similar issue with Revit.
    2. Ribbons are the default interface, However you can switch your workspace to AutoCAD classic or even customize user interface as you wish.
    2002-12
    Cairo
    174
    You can also check the new features in AutoCAD 2018 that may have a solution to the this issue.
    http://www.autodesk.com/products/autocad/features
  1. Replies: 2
    Last Post: 2015-10-20, 02:50 PM
  2. Replies: 0
    Last Post: 2015-08-07, 03:47 PM
  3. AB104-2: Autodesk® Revit® Architecture for AutoCAD® Architecture Geeks
    By Autodesk University in forum Architecture and Building Design
    Last Post: 2014-11-30, 01:07 PM
  4. Replies: 12
    Last Post: 2012-01-09, 04:43 AM
  5. Package Autocad Architecture with Revit Architecture
    By brian.114831 in forum Revit - Platform
    Last Post: 2007-11-14, 04:16 PM
