Results 1 to 6 of 6
Thread: AutoCAD LT System Variables
    2015-12
    23
    Default AutoCAD LT System Variables
    Forgive me if this has been addressed before.
    Is there a way to print out an entire list of system variables and their values? I have a hard time remembering between updates which ones I need to fix to my liking.
    Turlock, CA
    6,420
    Default Re: AutoCAD LT System Variables
    Regular acad has a lisp to save/reset all the vars. And there is the Express Tools SYSVDLG command. But I'm not aware of anything that would work in LT.
    C:> ED WORKING....
    LinkedIn
    2015-12
    2,095
    Whenever you're fiddling around with system settings, log the change along with a reason why. Then you can refer to the log later on, rather than relying on memory or a generic list of all settings.
    2015-12
    23
    Thanks for the comments. Now I have another problem. Every time I open my new version (2018 ) I have to go in and reset all those SV settings that I've now figured out. I KNOW there's a command that retains those settings, but I can't find it. Help please!
    Earth
    9,805
    Which settings specifically Kristi? Different things are stored/saved in different places.
    Some SV are stored in the DWG file, others in the profile/registry, others not saved at all.
    R.K. McSwain | CAD Panacea |
    2004-08
    Iron Station, NC
    3,198
    If you enter SETVAR at the command line, then ? then you can then select * and it will list them all. I just had to do this to find out why someone's machine wasnt acting the same as mine. saved a ton of time. You can then print out the contents of your command history, although I just opened it in notepad so I could compare the two files.
    *EDIT* sorry late to the party.
  1. Deployment of Registry-S​aved System Variables - AutoCAD 2013
    By mc-lemons in forum CAD Management - General
    Last Post: 2013-06-13, 04:11 PM
  2. Missing New System Variables for AutoCAD 2008
    By rbdome in forum AutoCAD General
    Last Post: 2008-08-28, 12:12 AM
  3. AutoCAD 2007 list of system variables
    By madcadder in forum AutoCAD General
    Last Post: 2006-09-13, 03:46 PM
  4. Compare AutoCAD system variables between drawings
    By Buffeldrek in forum AutoCAD General
    Last Post: 2006-07-02, 06:34 PM
  5. Replies: 8
    Last Post: 2006-06-14, 05:56 PM
