Thread: Room Identity Data & Finishes
    2017-03
    Question Room Identity Data & Finishes
    Hi,
    For example, if you have set the wall to a 'plaster' finish in the room identity data, but want to change the wall in that room to a tiled finish. Obviously you have to edit the wall type, but also have to change the wall finish in the room identity data.
    My questions would be, if it's possible to extract or link the actual finishes (internal side) used in a wall, floor or ceiling type directly to the room identity data or schedules?
    Thanks in Advance.
    19
    Default Re: Room Identity Data & Finishes
    This is on my list of to do things using the Revit API, but haven't had the time. Has anyone tried this? Perhaps this can be posted in the Revit API forum.
    AUGI Addict DaveP's Avatar
    2002-12
    St Paul, MN
    1,560
    This isn't exaclty what you're looking for, but the Roombook AddIn from Autodesk is similar
    https://apps.autodesk.com/RVT/en/Det...ng=en&os=Win64
    Go back to AutoCAD? I'd rather lose my right arm!
    2017-03
    @sdarali: I can re-post in the API forum, if the admins allows reposting?
    @DaveP: This plugin is only useful for quantity take-off, it doesn't seem to be working as per my intentions.
    Would it be possible to have the wall, floor and ceiling finishes as a 'shared parameter', so it can be scheduled across a project?
    2011-01
    87
    I was going to suggest the same thing Yuri.
  1. Ceiling Identity Data
    By charliep in forum Revit Architecture - General
    Last Post: 2009-06-10, 03:37 PM
  2. Stacked walls and identity data
    By clog boy in forum Revit Architecture - General
    Last Post: 2009-05-15, 02:24 PM
  3. Identity data - new param for walls?
    By still.james in forum Revit Architecture - General
    Last Post: 2008-09-09, 11:49 AM
  4. Identity Data
    By harkeychad in forum Revit Architecture - General
    Last Post: 2008-07-20, 09:21 AM
  5. Profiles - Missing Identity Data
    By kstephens in forum Revit Architecture - General
    Last Post: 2006-11-04, 03:01 AM
