Thread: going from 2014 to 2016 -- contours vanish
    Cairo - no, not Illinois
    5,069
    Default going from 2014 to 2016 -- contours vanish
    I sent a finish surface file generated in c3d 2014 to a surveyor, who is running c3d 2016. The probem is that none of the contours actually show up in 2016. The contour labels appear, and if the label line is dragged around the labels will update as the cross the (invisible) contours. Displaying TIN lines show that the surface is there -- style is set to display major and minor contours, and the layers assigned to the contours is turned on and thawed.
    My fall back -- will be to extract all the contours from the surface as lwplines at elevation, and send them as a separate file. But I would like to understand WTF is going on between 2014 and 2016.
    Any ideas?
    2004-08
    Iron Station, NC
    3,198
    Default Re: going from 2014 to 2016 -- contours vanish
    I've seen something similar to this happen before, it was a corrupted drawing, the solution in that instance was to copy and paste everything into a fresh drawing. As opposed to extracting contours can you send the landxml file? it may be quicker and provide a more accurate surface model at their end.
    2014-08
    448
    what is your level of detail set at. Just than into this lately. didn't make the contour all the contours disappear just some.
  1. 2016: Revit MEP 2014 & 2016 Generic Tee Fitting Family Pipe Connectors
    By JKRevit in forum Revit MEP - Families
    Last Post: 2016-04-20, 10:35 PM
  2. 2016: Custom Structure Part from 2014 to 2016
    By tntdraftsol in forum AutoCAD Civil 3D - Pipes
    Last Post: 2016-04-19, 01:35 PM
  3. Replies: 1
    Last Post: 2015-12-11, 05:00 PM
  4. Entourage RPC people vanish after Rendering!!
    By passerpawn_tech in forum Revit - Rendering
    Last Post: 2006-01-19, 02:46 PM
