Results 1 to 10 of 15
Thread: Automatically Delete BAK Files
    100 Club jsr13's Avatar
    Virginia - USA
    130
    Default Automatically Delete BAK Files
    I'm only vaguely familiar with batch files, but I remember hearing some time ago that you can create a batch file that can be run each night to delete all of the BAK files on the server each night before our backup routine is run to cut down on the size of the backup. It would need to be able to delete files in the subfolders on our Projects server.
    I feel like this should be a very simple thing, but not having the background with batch files makes the websites I've found dealing with them a bit confusing.
    Can anyone help??
    Thanks in advance!!!
    Jeff Rayhorn
    Sinclair Pratt Cameron, P.C.
    Consulting Structural Engineers
    Virginia Beach
    Virginia, USA
    100 Club RobertAitken's Avatar
    2000-10
    Sunny Scotland
    148
    Default Re: Automatically Delete BAK Files
    Quote Originally Posted by jsr13
    Can anyone help??
    Yep. No problems.
    Change to the drive you want the bak files deleted from e.g. T:
    Batch file should read
    t:
    cd\
    Echo Now eleting all BAK files on drive T:
    del *.bak /s /a
    That's about it
    Or you could run a find/search on the drive in question. CTRL-A then press the del key.
    HTH
    Robert Aitken
    Virginia - USA
    130
    Ok - I just set up a set of test directories, populated them with BAK files, & created the batch file. I ran it & the files are still there. The prompt was there & gone so quick that I couldn't see what was happening, but the files remain. This is the file:
    \\SPC_SERVER1\Jobs\jeff\test
    cd\
    REM Echo Now eleting all BAK files on \\SPC_SERVER1\Jobs\jeff\test:
    del *.bak /s /a
    Any ideas?
    Jeff Rayhorn
    Virginia Beach
    Virginia, USA
    100 Club Lemons's Avatar
    2001-06
    Beautiful Charleston, South Carolina
    149
    cd\
    del *.bak /s /a
    Any ideas?
    Go to your command prompt and type the commands one at a time and see what you get.
    Drop me off in Asheville.
    Houston
    7,520
    cd\
    del *.bak /s /a
    Any ideas?
    I'm not in front of a M$ network at the moment, but I believe you will have to map a drive letter first. I don't think you can use UNC paths at the command prompt.
    net use Z: \\SPC_SERVER\Jobs\
    ---do you stuff here --
    net use z: /delete
    Let us know....
    100 Club pnorman's Avatar
    2005-02
    Calgary
    179
    No, the CMD.exe does not support UNC paths! Bummer!
    You can add:
    pause
    to your batch file if you want to see what the window that flashes up faster than you can say "delete my .bak's"
    you will need to be there to "press any key to continue" though so maybe just use it for testing....
    good luck
    Virginia - USA
    130
    Thumbs up Re: Automatically Delete BAK Files
    Ok - tomorrow I'm going to 'pause' the batch file, I'm going to change it to the 'J:' drive (which is where it's mapped), and go through the commands one-by-one.
    I didn't realize that was a limitation of CMD.EXE.
    Will let all of you know how it goes in the morning!
    Jeff Rayhorn
    Virginia Beach
    Virginia, USA
    2000-10
    Sunny Scotland
    148
    Jeff,
    Map a drive to the server area (SPC_SERVER1Jobsjefftest) change to that drive and delete the bak files.
    net use Z: SPC_SERVER1Jobsjefftest
    z:
    cd\
    del *.bak /s /a
    :disconnect
    net use z: /d
    if exist z:\*.* goto disconnect
    Sometimes the net use command can throw a wobbly and not disconnect the drive when requested. The loop just makes sure it keeps trying until it has disconnected.
    Hopefully that will work
    Robert
    Active Member rtorres's Avatar
    2002-06
    Somerset, NJ
    86
    Red face Re: Automatically Delete BAK Files
    I would just ...
    Open NOTEPAD and copy & paste this....
    delete c:\my-folder\*.bak
    delete d:\ANOTHER-folder\*.bak
    delete e:\yet-another-folder\*.bak
    delete f:\and-noe-more-folder\*.bak
    Now save it as ...... CLEAN-BAK.BAT ......... in c:\my-folder
    Now go to START> SETTINGS> CONTROL PANEL>SCHEDULED TASKS
    Point to the file and have it run as YOU see fit.
    (Obviously, edit the folder names & drive letters for your use)
    Hope that helps
    ... SMILE ... the work will always be there, but you don't have to be there .... try again tomorrow.
    Certifiable AUGI Addict Robert.Hall's Avatar
    2004-07
    Detroit Michigan
    2,510
    Quote Originally Posted by rtorres
    I would just ...
    Hope that helps
    Great tip, thanks for posting.
  1. Can't open or delete files
    By capstone in forum AutoCAD General
    Last Post: 2011-06-20, 03:02 PM
  2. Keep 2012 from automatically convertinging files
    By markleasor in forum Revit Architecture - General
    Last Post: 2011-05-07, 01:50 AM
  3. Automatically delete *.BAK, plot.log, acadstk.dmp, and acad.err files
    By CAD Brad in forum CAD Management - General
    Last Post: 2009-02-12, 05:41 PM
  4. Automatically jump to opened files
    By lvsuccess in forum AutoCAD General
    Last Post: 2008-08-26, 05:35 AM
  5. files swapping information automatically
    By shenderson in forum Revit Architecture - General
    Last Post: 2007-03-10, 02:00 PM
