Thread: Areas not printing/plotting when exporting to DWF/PDG
    2016-12
    4
    Default Areas not printing/plotting when exporting to DWF/PDG
    We've been experiencing problems while plotting elevation sheets in realistic views to DWF/PDF. Parts of the drawing just don't print (i.e. are"white boxes"). We've tried changing the settings and switching from raster to vector processing, but there does not seem to be a consistent solution for the problem. Has anyone else had the same issue? It has to be a hardware/software problem. Is AutoDesk aware of the issue?
    2002-09
    Madison, WI
    5,688
    Default Re: Areas not printing/plotting when exporting to DWF/PDG
    I've gone to always printing raster vs vector. That usually eliminated the issue.
  1. 2016: Areas not printing when exporting to DWF/PDG
    By chilke1234 in forum Revit - Plotting/Printing/Exporting
    Last Post: 2017-04-14, 04:19 PM
  2. 2015: File name - printing PDF and exporting (DWG)
    By eliyahoo in forum Revit Architecture - General
    Last Post: 2015-10-26, 11:38 AM
  3. Printing or exporting CTB settings *
    By rclayton in forum AutoCAD Wish List
    Last Post: 2012-10-10, 12:16 PM
  4. Exporting areas to Excel
    By gfocaraccio in forum VBA/COM Interop
    Last Post: 2009-01-09, 03:48 PM
  5. Printing or exporting CTB settings
    Last Post: 2006-02-02, 03:43 AM
