Results 1 to 7 of 7
Thread: Control of non-system variable settings
    2008-09
    94
    Default Control of non-system variable settings
    Is there a way to automate control (by lisp or otherwise) of non-System Variable settings?
    Specifically, I'd like to uncheck the default "Turn off layers not found in layer state" option in the Layer States Manager (LMAN) on new deploys. I'd like to add it to the startup or to a general "setup" lisp command when I'm setting up a new machine. Since it's a set it once and ACAD will remember it - the startup route would be overkill. Using the System Variable dialog (express tool), I was unable to determine a system variable associated with that setting.
    At this point the only way I can turn it off is to manually uncheck it after running the LMAN command. Any suggestions?
    2004-08
    Iron Station, NC
    3,198
    Default Re: Control of non-system variable settings
    I would assume it is stored with the template. So set it there and it should be good to go if you are using a shared template. Something you can do that provides more data than the express tool is the SETVAR command. It will give you every variable, even the ones not provided by the express tool.
    Earth
    9,804
    2
    The setting you are looking for is stored in the registry, here:
    HKEY_CURRENT_USER\SOFTWARE\Autodesk\AutoCAD\Rxx.x\xxxx-xxxx:xxx\Profiles\[Profile_Name]\Dialogs\AcLayerApps:LayerStatesManager
    It's a 32-bit DWORD named "LayerNotFound".
    1 = checked
    0 = not checked
    You can read / write this setting using lisp, like this:
    (vl-registry-read
         (strcat "HKEY_CURRENT_USER\\" (vlax-machine-product-key) "\\Profiles\\" (getvar "cprofile") "\\Dialogs\\AcLayerApps:LayerStatesManager")
         "LayerNotFound"
    (vl-registry-write
         "LayerNotFound" 0
    R.K. McSwain | CAD Panacea |
    2001-03
    Tallahassee, FL USA
    3,667
    HKEY_CURRENT_USER\SOFTWARE\Autodesk\AutoCAD\Rxx.x\xxxx-xxxxxx\Profiles\[Profile_Name]\Dialogs\AcLayerApps:LayerStatesManager
    1 = checked
    0 = not checked
    (vl-registry-read
         "LayerNotFound"
    (vl-registry-write
         "LayerNotFound" 0
    I added the bottom vl-registry-write part to my Acaddoc.lsp file years ago. I use Layer States all the time and all of them only modify groups of layers. Allows me to apply Layer States from the ribbon drop-down.
    2008-09
    94
    1 = checked
    0 = not checked
    (vl-registry-read
         "LayerNotFound"
    (vl-registry-write
         "LayerNotFound" 0
    Fantastic! This works perfectly. Thanks rkmcswain.
    Follow up question. Is there a resource that lists other settings that are stored in the registry like this? I've only ever known of System Variables and I believed the other non-System Variable settings to be untouchable (except manually).
    Earth
    9,804
    No list that I am aware of.
    I just used Process Monitor to watch registry activity while I was changing the setting.
    2020-02
    6
    Superb. Thanks rkmcswain, exactly what I was looking for. Have incorporated this into a script to load and refresh my company-standard layers
  1. System Variable to Control Wipe Out Frames
    Last Post: 2012-07-20, 04:26 AM
  2. Compare System Variable Settings
    By kerbocad in forum AutoCAD Tips & Tricks
    Last Post: 2009-04-16, 09:20 AM
  3. IMAGEFRAME System Variable
    By joeswantek in forum AutoCAD General
    Last Post: 2007-06-21, 05:11 PM
  4. Mtextfixed variable and migrated settings
    By Mamma Jamma in forum AutoCAD Tips & Tricks
    Last Post: 2006-11-01, 01:15 PM
  5. System Variable to control text stacking or not stacking
    By jhohman in forum AutoCAD General
    Last Post: 2006-09-21, 09:36 PM
