Thread: Applying Multiple Visbility Parameters
    2017-04
    Default Applying Multiple Visbility Parameters
    Is there a way to apply a type and instance parameter to an object?
    2011-04
    32
    Default Re: Applying Multiple Visbility Parameters
    Quote Originally Posted by D_Velez View Post
    A single parameter can only be instance OR type, not both at the same time.
    However you can have some parameters that are set to instance and others that are set to type. It is very important to get right which one is which.
    You cannot use an instance parameter's value in a formula for a type parameter, but you can use a type parameter in the formula of an instance parameter.
    ...but I'm still not sure what any of this has to do with multiple visibility parameters :/
  1. applying multiple object markers
    By randall.hanes in forum AutoCAD Civil 3D - Sections
    Last Post: 2009-10-28, 09:20 PM
  2. Ability to Delete Parameters Multiple Parameters
    By Inventor Wishes in forum Inventor Wish List
    Last Post: 2008-08-18, 04:40 PM
  3. Applying Script To Multiple layouts problem?
    By pierredib in forum AutoCAD General
    Last Post: 2008-08-13, 01:08 PM
  4. Help with applying multiple Actions to a Dynamic Block
    By james.126519 in forum Dynamic Blocks - Technical
    Last Post: 2006-11-14, 09:07 PM
  5. Braces - Applying them on multiple gridlines quickly
    By Steve_Stafford in forum Revit Structure - General
    Last Post: 2005-06-21, 05:14 PM
