Auto Add Surface Spot Elevation Labels Along Feature Line or Polyline on Vertices
Summary: An option within the "Add Labels: Surface: to automatically add surface spot elevation labels along feature Line or polyline on vertices. Similar to "Create Points-Miscellaneous -] Polyline Vertices - Automatic"
Description: An option within the "Add Labels: Surface: to automatically add surface spot elevation labels along feature Line or polyline on vertices. Similar to "Create Points-Miscellaneous -] Polyline Vertices - Automatic"
Product and Feature: AutoCAD Civil 3D - Annotate (Civil 3D Labels)
Submitted By: ericv.154537 on 04/17/2017
Re: Auto Add Surface Spot Elevation Labels Along Feature Line or Polyline on Vertices
In the mean time one could make a General Line/Curve label with a reference text component for a surface. Anchor the component to the beginning of the line/curve. Then use that style with the 'multiple' option while labeling to apply it to the entire object with one selection.
I use a similar style to label my grading feature lines with elevations at their ends with the slope % and direction at their mid-points. I use these only for my use while grading so I can see whats going on all around. On final plans I use a surface spot label but only at key locations.
http://forums.augi.com/showthread.ph...-Feature-lines
- You may not post replies
- You may not edit your posts
Forum Rules
