jastect
I've had this issue for more than 20 years. I've used regular AutoCAD and LT in multiple versions. I know we used to use \X to push next line below line in a dimension string. This worked sometimes. The text line would move but the dimension line would break randomly. Now, we have text boxes that do the same thing. Even if I try the \X, it disappears afterward.
I still have this issue. It can start with the line not breaking and then break if I change the location or size. I always set up dimensions the same way. I want text centered and above as a default and multiple lines to occur above and below an unbroken dimension line. If I use the grip and center it on the line, I want the line to not disappear.
Anyone know how to fix this?
