Results 1 to 1 of 1
Thread: project polyline to contour line with interpolation each vertex of polyline between contour line
    2006-05
    Tehran-IRAN
    23
    Default create center line between polygons
    Hello my dears:
    First, I apologize for referring you to another site.
    because of this that I'm poor Language English and I wanted to save time.
    in attached file I pose a problem,
    I want draw center line (polyline) between the exist polygons,
    regardless of how they connect in start point and end point.
    Unfortunately, I search in internet but do't got the results
    Except in ArcGIS-Esri Software
    Is in the map3d software can be draw centerline like ArcGIS-Esri (Collapse Dual Lines To Centerline) or need to code
    I am grateful guide
  1. 2015: Adding the same contour polyline to a surface multiple times
    By dpresley58437170 in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2015-02-27, 05:01 AM
  2. Polyline issue with global width... vertex between line and arc
    By david.musrie346034 in forum AutoCAD LT - General
    Last Post: 2012-12-11, 10:36 PM
  3. Polyline contour labeling in Civil 3D
    By jwissler in forum AutoLISP
    Last Post: 2009-02-26, 10:00 AM
  4. why does the imported contour line NOT following the contour line!!!
    By Richard McCarthy in forum Revit Architecture - General
    Last Post: 2004-10-25, 12:34 PM
