Any thoughts or impressions. how long to download and install off the net
I dont use the browser download or install mow, or the download manager. Use the virtual agent
http://autodesk.creativevirtual15.co...t.Front%20Desk
took about 15-20 minutes to downoad and about the same to install.
2 issues that stand out.
polyline grip editing has a bug, which is annoying but workable, you can only perform one grip edit at a time, then need to deselect and reselect the polyline to perform the next edit.
and the thing that stopped us in our tracks until the first update is this issue:
https://forums.autodesk.com/t5/autoc...r/td-p/7061292
it loads faster than 2017.
i've downloaded and install it, but we haven't started using it yet.
@ ccowgill.....i see there are 5 parts for the download for the suite we have. do you download each one into a folder?
How are they deployed?
i used the install now and it took several hours.
Suites are a little different, you have to download all 5 parts, then start the install with the 001 part. You could also just download the c3d part only if that is all you use, and just use your suite licensing for it. Download time is dependent in you connection speed
