Thread: What is current snap angle?
    2016-04
    California
    63
    Default What is current snap angle?
    Hi guys,
    Is there a command to find out what the current snap angle is. IE not change it but just read it.
    Thanks
    2004-08
    Hartford, Michigan
    3,192
    Default Re: What is current snap angle?
    Christopher T. Cowgill, P.E.
    AEC Collection Civil 3D 2018
    Windows 10
    2016-04
    California
    63
    Thanks Chris,
    But this command does not tell you what (in my case) someone else has set the snap angle to. I just want to find out what it currently is set to. This way if I change it I can go back to the original setting if required. Is there a technique to see this value?
    2004-08
    Hartford, Michigan
    3,192
    perhaps I do not understand what you are tyring to get. if you type in SNAPANG at the command line and hit enter, in the value that is displayed before you type it shows what the current snapang is. if you type in (getvar "snapang") it returns the vale in radians. so you would need to multipy by 180 and divide by PI to get your degrees. its just easier to type in SNAPANG and then hit escape if you dont want to change it.
    Windows 10
  1. Rotation angle in Properties not to current UCS
    By mtc.139414 in forum AutoCAD General
    Last Post: 2007-12-18, 08:16 PM
  2. Snap only to Points in Current View
    By mbickerton in forum AutoCAD General
    Last Post: 2007-11-01, 11:23 AM
  3. Snap to current layer only
    By acadwishlist in forum AutoCAD Wish List
    Last Post: 2006-09-11, 04:46 PM
  4. Rotating pick box when using snap angle...
    By cnash in forum AutoCAD LT - General
    Last Post: 2005-11-14, 03:55 PM
  5. Snap angle
    By BCrouse in forum AutoLISP
    Last Post: 2005-04-21, 08:25 PM
Tags for this Thread
