Thread: DISAPPEARING TEXT AND POLYLINES NOT DISPLAYING CORRECTLY
    2004-06
    Slidell, Louisiana
    972
    Default DISAPPEARING TEXT AND POLYLINES NOT DISPLAYING CORRECTLY
    Not sure what happened. was working in a drawing creating a surface and using two vertical viewports in model space.
    something happened to cause my drawing to display polylines as outlines and not solid. and when selected they show as shaded with some transparency. and the shading
    is sectioned off at every feature line it crosses. in addition to that some Tahoma style text is invisible. can be selected, but is only visible when selected.
    i've set shademode to 2dwireframe, fillmode is on, ucs is world, set to plan. i'm at a loss of what to do.
    and now, any text i create using Tahoma disappears, but not romans.
    well apparently i screwed something major up, because it's affected my autocad globally. any pline i create in new drawings are doing the same thing.
    2004-06
    Slidell, Louisiana
    972
    Default Re: DISAPPEARING TEXT AND POLYLINES NOT DISPLAYING CORRECTLY
    well, not sure what fixed the problem. i did set all the variables as mentioned above. finally saved and exited the program. a upon re-launch everything was back to normal.
    2014-08
    448
    Hi
    Sounds like a video card issue. It happens occasionally on my current workstation just out of the blue. save close reopen everything is fine
  1. AEC Objects not displaying correctly
    By ewhite in forum AutoCAD Civil 3D - General
    Last Post: 2009-11-03, 03:49 PM
  2. Model not displaying correctly.
    By bryanl in forum Revit Architecture - General
    Last Post: 2006-10-23, 03:02 PM
  3. Polylines with Width not Plotting correctly
    By john.103073 in forum AutoCAD LT - General
    Last Post: 2006-06-23, 06:17 PM
  4. Chinese text not displaying correctly in drawings
    By mhinnebu in forum AutoCAD General
    Last Post: 2005-07-27, 10:19 PM
