we are running C3D2017 & have a road design that is made of LH corridor & RH corridor format together with a centreline alignment but are having problems getting the data extracted so the surveyor can stake out/set out the road edges/ curbs/ channels/ storm drains. We can do a report for the centre line alignment using station/chainages with set distance offsets, the problem is this report doesn't give us transition points, eg. the point from a curb/ kerb straight string to curve string & vice versa or where the road widens & narrows each side, also we cant extract the low points for storm drains around these curbs/kerbs. Surely there must be a report for the road edges as how can you stake/set out a road from just a centreline or are we building the model wrong & should be using something other than corridors like doing the edges as alignments??
