Thread: Accessing object properties with an objectOD
    2017-04
    10
    Default Accessing object properties with an objectID
    Beginner Question:
    I have a selectionset of objectIds, i guess its called an objectidcollection. How can i get the layer of each of these? I thought something like myObjectID.layer would work but it doesnt. I also tried creating an Object using:
    Object myNewObj = objID.(GetObject (OpenMode.ForRead) as Object
    and then using:
    myNewObj.layer
    but that doesnt work either. Im sure this is very simple but i cant figure it out or find example code like this anywhere.
    Thanks for any help.
    James
    2017-04
    10
    Default Re: Accessing object properties with an objectOD
    Ok, figured it out. I have to cast the object to an Entity then use myEnt.layer.
    Am i supposed to answer my own questions if i figure them out? Or delete the thread? Or just let it be?
    Thankx
    Programming Moderator BlackBox's Avatar
    2009-11
    5,243
    Quote Originally Posted by jrauden748232 View Post
    Glad you got it sorted; we all need help sometimes, but figuring things out for ourselves is the best way to learn.
    Answering your own questions helps someone else down the line save time, which is always appreciated.
    Cheers
    Computer Specs:
    Dell Precision 3620, Core i7-7700K 4.2GHz, 32GB RAM, Samsung 970 Pro M.2, 8GB NVIDIA Quadro P4000
  1. Accessing object inside block reference
    By a.ghensi689507 in forum VBA/COM Interop
    Last Post: 2015-03-23, 10:53 AM
  2. Copy Object Properties Before Creating a Similar Object
    By acadwishlist in forum AutoCAD Wish List
    Last Post: 2012-07-01, 03:03 AM
  3. New object properties not matching layer properties
    By domniki in forum AutoCAD General
    Last Post: 2010-03-23, 09:48 AM
  4. Accessing embedded object data
    By anderson.scottglen in forum AutoLISP
    Last Post: 2009-04-09, 06:57 PM
  5. Object properties palette not showing selected Objects properties
    By timothyjturner in forum AutoCAD General
    Last Post: 2007-08-10, 05:21 PM
