Thread: Debugging without reopening acad everytime
    2017-04
    10
    Default Debugging without reopening acad everytime
    Another beginner question: im coding in VS so everytime i build my solution i have to reopen acad to test it. Is there a simple way to keep acad open and simply use netload and reload my .dll instead of having to wait for acad to open each time i build my code? I tried building it in VS then reloading the .dll with NETLOAD in acad but that doesnt seem to work.
    Thank you again for any help.
    James
    Programming Moderator BlackBox's Avatar
    5,198
    Default Re: Debugging without reopening acad everytime
    Welcome to the world of .NET development.
    Unfortunately, no - there is no such thing as NETUNLOAD (certainly not yet)... .NET Assemblies can only be loaded once per session, so the closing, and relaunching of Acad.exe is necessary.
    Depending on versions of VS, and AutoCAD, you might consider using 'Edit and Continue' as a stop gap in the interim.
    Cheers
    "Potential has a shelf life." - Margaret Atwood
    AutoCAD, and Civil 3D Certified Professional | Autodesk Authorized Developer
    2017-04
    10
    Wow, i never would have thought that. Thanks for the quick response!
    5,198
    Quote Originally Posted by jrauden748232 View Post
    No worries; everybody starts somewhere.
    Cheers, dude.
  1. 2017: Revit 2017 - Work disappearing after Synchronizing/Closing/Reopening?
    By nharburger in forum Revit Architecture - General
    Last Post: 2017-01-09, 11:16 PM
  2. 2013: linked dwg files flipped when reopening revit file
    By Philipp Kühne in forum Revit - Platform
    Last Post: 2013-11-20, 09:22 PM
  3. Refresh Causes Crash Everytime
    By bjschw in forum NavisWorks - General
    Last Post: 2009-07-07, 05:19 PM
  4. Everytime I pan, Revit autosaves
    By mattcummins in forum Revit Architecture - General
    Last Post: 2008-12-15, 05:09 PM
  5. Problems debugging ACAD 2008 with VS 2005
    By ivan.markov in forum Dot Net API
    Last Post: 2007-07-10, 11:23 PM
