Results 1 to 1 of 1
Thread: Change color of Text in Table
    2003-06
    121
    Question Change color of Text in Table
    So I am reading a value from a text file and checking the first column of a table for the value and if the value exist in the cell then I want to change the color of the text to cyan. Not sure why this isn't working... any help would be appreciated.
    I dimension the color and set it...
    GetInterfaceObject ("AutoCAD.AcCmColor.22")
    Dim mycolor As New AcadAcCmColor
    mycolor.SetRGB 0, 255, 255
    then get the table with a selection set. In this particular drawing there is always only one table so I could do it other ways but this was quick.
    Open selfile For Input As mIntFilenumber
    If Not objss.Count = 0 Then Set objtable = objss(0)
    Do While Not EOF(mIntFilenumber)
        Input #mIntFilenumber, textline
        cnti = objtable.Rows
        For RowCnt = 0 To objtable.Rows
            If InStr(textline, objtable.GetCellValue(RowCnt, 0)) > 0 Then
                objtable.SetCellContentColor RowCnt, 0, mycolor
            End If
        Next RowCnt
    Loop
    then absolutely nothing about the table changes. I watch it iterate and it finds the match but does not change the color. What am I not doing.
  1. 2010: AutoCAD Table Linked to Excel, Text Does Not Plot by Color, is too light
    By SwizzleStick in forum AutoCAD Tables
    Last Post: 2015-06-12, 04:27 PM
  2. change a text in table 1 and automated modifi in table 2
    By bbogc694889 in forum AutoCAD Fields
    Last Post: 2015-04-20, 02:35 PM
  3. How to change text color
    By some buddy in forum Revit - API
    Last Post: 2009-10-20, 05:14 PM
  4. How to change color of TextNote element's Text
    By shifali.a in forum Revit - API
    Last Post: 2009-05-06, 11:43 AM
  5. Globally change Text Style in a Table
    By Rico in forum AutoCAD Tables
    Last Post: 2005-10-27, 10:01 PM
Tags for this Thread
