Thread: Frames
    2017-03
    25
    Default Frames
    Hi everyone.
    I'm creating sheets from some alignments. To do so I create frames and then select 'Create Sheets'. The problem is that for some reason the profile is not entirely drawn. I will saw you some pics.
    In the first pic you can see the profile. The red line is the proposed road, the green line is the existing ground. As you can see the profile is entirely drawn.
    In the next pic you can see one of the profiles drawn form the frames, there is a gap. As you can see in the last chainages the profile is not drawn. How can I fix this?
    Thank you for your time.
    2017-03
    25
    Default Re: Frames
    Solved
    mmmmmmmmmmmmmmmmmmm
  1. Concrete frames
    By cmbyrd77 in forum Revit Structure - General
    Last Post: 2009-10-28, 01:20 AM
  2. Need Help with View Frames!
    By dbreedlove in forum AutoCAD 3D (2007 and above)
    Last Post: 2009-07-09, 02:24 PM
  3. Brace frames in RS4
    By david_peterson in forum Revit Structure - General
    Last Post: 2006-11-01, 04:18 PM
  4. Replies: 4
    Last Post: 2006-10-23, 06:30 PM
  5. Structural frames
    By kwong in forum Revit Architecture - General
    Last Post: 2006-06-22, 01:15 AM
Tags for this Thread
