Thread: Revit Group in Naviwork
    2016-06
    Default Revit Group in Naviwork
    Hii Everyone,
    I exported Revit file into Naviswork to create the 4D simulation and I found naviswork does not hold the Revit groups and assemblies.I am creating a construction simulation for the precast 5 story building, in which each group is one space (Kitchen, Living etc) it takes so much time to group manually in naviswork.Is it possible to create parameters in Revit (for each group)and bring it back to naviswork or any simplest method that I can do in naviwork.
    Thanks,
    Manoj
    2017-02
    4
    Default Re: Revit Group in Naviwork
    +1
    Same question from me
    100 Club a_meteni's Avatar
    2002-12
    Cairo
    128
    Check this link
    Best Regards
    Ali
    BIM Manager Brian Myers's Avatar
    2003-02
    St Louis, Missouri
    1,797
    2 members found this post helpful.
    Technically you could add a parameter in Revit which could then be filtered into Sets in Navisworks. I do this often with systems such as fire protection, sanitary, gas, etc.
    It's easy, but it can be time consuming if you need to do this hundreds of times.
    Brian Myers
    BIM Manager | Author | Consultant
    LinkedIn Profile
  1. Replies: 2
    Last Post: 2012-09-21, 06:04 PM
  2. S.F. Bay Area Revit User's Group Meeting - Aug. 17th - Meet the Revit Developers!
    By hand471037 in forum Revit Architecture - General
    Last Post: 2004-08-16, 04:08 PM
  3. Replies: 0
    Last Post: 2004-08-13, 05:56 PM
  4. Autodesk Revit User Group & Free Intro to Revit class
    By Melarch in forum Revit Architecture - General
    Last Post: 2004-05-12, 10:17 AM
