Thread: System families in formulas?
    2007-08
    New York, NY
    189
    Default System families in formulas?
    I am building a window family and I would like to use the system families of Sill Height and Head Height in formulas (for example to calculate the Rough Opening Height -- Sill Height + Height = RO Height). But those parameters don't exist in the family, only in the project. Is there a way to do this?
    Thanks in advance!
    2015-08
    199
    Default Re: System families in formulas?
    That doesn't make any sense. Sill Height is from floor level to underside of origin level in the family so it's often a value of 900-1200mm (3' - 4'). You need to add a parameter of 'rough opening offset' which should be 10mm (3/8") or so and then use that to offset the opening cut in the family from the outside of the frame of the window.
    Then you would calculate your rough opening by adding width + (2 x rough opening offset) and then do the same for height.
  1. 2014: Mathematical formulas in loadable families
    By Silleke in forum Revit Structure - Families
    Last Post: 2014-03-18, 06:58 AM
  2. Performance of Formulas in Families
    By iru69 in forum Revit Architecture - Families
    Last Post: 2010-11-09, 12:18 AM
  3. Families and Formulas ---- help
    By j_starko in forum Revit Architecture - Families
    Last Post: 2010-11-03, 04:57 PM
  4. Using formulas but not in families, is it possible?
    By rtaube in forum Revit Architecture - General
    Last Post: 2010-10-22, 01:12 PM
  5. Formulas and Families
    By beegee in forum Revit Architecture - Families
    Last Post: 2004-07-22, 10:59 PM
