Thread: I can't trim ellipse.
    2017-06
    Default I can't trim ellipse.
    I can not trim an ellipse like an attachment dwg file.
    2014 version users.
    If you know anyone, please answer.
    添付ファイルのように楕円トリミングができません。2014バージョンのユーザーです。
    ご存知の方がいらっしゃいましたら、返答お願いします。
    2015-10
    Belgrade, Serbia, Europe
    564
    Default Re: I can't trim ellipse.
    For some weird reason it won't trim yellow ellipse, but I used break command and broke it near intersections... Then finally I stretched end vertices of ellipse to intersections with horizontal line... The result is like it was trimmed...
  1. Trim to auto select all boundaries and directly go into trim mode
    Last Post: 2016-08-17, 02:41 AM
  2. Getting window trim to cut through compound wall trim or sweep?
    By Nasko in forum Revit Architecture - General
    Last Post: 2013-02-14, 04:49 PM
  3. Trim, trim objects/selection issue 2010
    By stevej.57608 in forum CAD Management - General
    Last Post: 2009-07-08, 04:09 PM
  4. Ellipse - Offseted as Ellipse, not as a spline.
    By harilalmn in forum VBA/COM Interop
    Last Post: 2009-06-09, 03:34 PM
  5. Trim not trimming back to selected trim boundary
    By Wwhite72082 in forum AutoCAD General
    Last Post: 2007-03-23, 01:47 PM
