Zones for Low Voltage Systems
Summary: There should be zones for low voltage systems like there are for mechanical systems
Description: Similar to the way a mechanical system may be limited to a particular part of a building, low voltage systems that run on a data network are limited in area they can serve by cable distances. Network cabling can only run 100m before it is considered "out of spec." Because of this data systems within large buildings have to be divided into zones served by cabling coming from different technology closets. It would be nice if those areas could be created as officially recognized zones in Revit, and all families with data connectors within a zone linked to that zone (or even the panels that serve that zone).
Product and Feature: Revit MEP - MEP Electrical Other - (Electrical)
Submitted By: n_withers on 06/13/2017
- You may not post replies
- You may not edit your posts
Forum Rules
