Thread: Help with autolisp (2 lisp programs in one lisp execution)
    Default Help with autolisp (2 lisp programs in one lisp execution)
    Hi to all My name Javier
    Thanks in advance to all that help with this one.
    I have a lisp program that use on every drawing, its my os1 lisp (osnaps). My problem is that when i execute another lisp program, my osnap lisp turn off and i have to invoke the os1 again. Can I include my os1 lisp at the end of other lisp programs. I would like to have the os1 execute after other lisp program executes. I included a lisp program to draw T profile and the os1 lisp. I would like for the os1 to execute after the TEE Profile is executed, so that i don't have to execute the os1 every time i execute a lisp program.
    Thanks
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Default Re: Help with autolisp (2 lisp programs in one lisp execution)
    Try:
    (defun c:T-profile ( / osmode pt1 CL SH T1 T2 pt2 pt3 pt4 pt5 pt6 pt7 pt8)
     (command "._layer" "_M" "SECTION" "")
     (setq osmode (getvar "osmode" ))
     (setvar "osmode" 0)
     (Setq pt1 (getpoint "\nEnter the point: ") ;Starting point;
           CL (getdist "\nEnter the Cap length: ")
           SH (getdist "\nEnter the Stem Height: ")
           T1 (getdist "\nEnter the Stem Thickness: T1 ")
           T2 (getdist "\nEnter the Cap Thickness: T2 ")
           pt2 (polar pt1 0 t1)
           pt3 (polar pt2 (/ pi 2.0) (- SH T2))
           pt4 (polar pt3 0 (+(/ CL 2) (-(/ T1 2))))
           pt5 (polar pt4 (/ pi 2.0) T2)
           pt6 (polar pt5 pi CL)
           pt7 (polar  pt6  (/(* pi 3)2) t2)
           pt8 (polar pt7 0 (- (/ CL 2) (/ T1 2)))
     (command "pline" pt1 pt2 pt3 pt4 pt5 pt6 pt7 pt8 pt1 "")
     (setvar "osmode" osmode)
     (princ)
  1. open Drawing using AutoLISP and run lisp routine
    By avinash patil in forum AutoLISP
    Last Post: 2016-03-07, 10:51 AM
  2. Replies: 2
    Last Post: 2012-08-30, 11:59 AM
  3. Autolisp vs Visual Lisp
    By neje in forum AutoLISP
    Last Post: 2009-03-08, 10:54 PM
  4. SLOW execution of lisp in 2006...
    By rlarabee.89652 in forum AutoLISP
    Last Post: 2005-10-05, 05:40 PM
