Thread: Printing
    2015-03
    4
    Question Printing
    Problem: When I print a layout tab the model space objects print in color, and the paperspace objects in black. I would like everything in black.
    Wasn't having this problem before. I use a work created ctb file used for printing black (monochrome). When I open the ctb file it looks ok.
    It seems the problem is the file because I have used the same ctb file with other drawings and it is ok. Has anyone else seen this and have
    a solution? I jump from 2015 to 2017 using the same ctb (if that has anything to do with it).
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,655
    Default Re: Printing
    CTB's only work for the basic 256 colors. Is the Plot Style set to Color_# for all layers in the Layer Manager while in Model Space?
  1. Replies: 1
    Last Post: 2017-03-06, 08:56 PM
  2. Simplified printing - printing interface upgrade
    Last Post: 2016-10-26, 11:46 AM
  3. Replies: 1
    Last Post: 2013-03-25, 08:55 PM
  4. 2012: Xrefs not printing or printing in light gray
    By bap020799 in forum AutoCAD Plotting
    Last Post: 2011-08-10, 07:28 PM
  5. Printing Hp Laserjet 5000- Customer Logo not printing solid
    By thomas.huckabee in forum AutoCAD Plotting
    Last Post: 2005-05-26, 08:42 PM
